How does the Oasis Hydronic heating system work?
Our Oasis is similar to a home boiler type of heating system. Our diesel burner however uses the on board fuel supply and operates on a 12 Volt DC battery power supply. The boiler system then pumps the hot fluid throughout the interior of the motorhome. The domestic hot water is heated On Demand as it is being used. No separate storage of hot water is needed. The main heat source is the diesel-burner. However the Oasis is equipped with one or two 120/240 VAC 1500 watt electric heating element that can provide up to an additional 10000 BTU as well as recover waste engine heat to use in the system. These three sources of heat can all be used at the same time as well.
