bluwtr49
Sep 14, 2014Explorer II
Deano56 wrote:
my older mh has this kind of molding on the lower part of the sides walls as you mentioned. Mine has a 1/2" wide strip that snaps in the center of the molding. Some of it I removed for body work only to find out a lot of the screws were braking off due to being rusty, some had to be drilled out. Maybe if you post a picture you could get faster responses.
If you haven't already go over to the Beaver forum and check. This is not an uncommon problem in any older coach. Since you're in Portland BCS in Bend would be a great resource if you haven't already contacted them.
