"wvaincourt".....Welcome to the forum. You could have one of two issues. Either your struts are worn out or there is more added bedding to the to bed than originally intended by the manufacturer. Many add new mattresses or pillow toppers that increase the weight beyond what the struts can support.
If you don't have any additional weight than new struts may be needed. Typically, you can look at the side of the struts and see some codes or markings. If you plug those numbers into a Google search, they'll probably give you replacement info. Then go to Amazon and order.
