Dnich76
Feb 12, 2022Explorer
Bedroom outlets
I have a Pacearrow 37C. The outlets in my bedroom have all dropped down to 45 volts and I don’t understand why. I tried resetting the GFCI in the bathroom, like I have read on some other forums, but t...
Y-Guy wrote:
I'm not sure this will be the case in your situation or resolve your problem. But on most RVs the use the backstab jacks on the back of the outlet instead of anchored down by screws. Loose electrical wires can cause electrical fires, interruption in power as well as damage to the outlet with melted or singed parts due to increased heat.
As you can imagine in an RV the bouncing and moving may cause issues. After having issues with mine I went through the whole RV and changed from backstab to proper screwed anchor wiring.
