tropical36 wrote:
viajante wrote:
We just had an odd and infuriating problem with our bedroom slide. When I pressed the extend button, the slide goes out about 2 inches, then stops. It retracts fine. The living room slide works fine. I tried running the engine and also kicked on the generator. Neither worked.
Suggestions please.
Be sure it's level and the voltage is up around 13+, although 12.5 should get it.
No cigar, then disconnect the drive and manually crank it out, for smoothness and listening for any noise.
I agree with trying to crank it out manually. My slide has a safety switch, if it comes up against an obstruction (as appossed to an obstetrician :) it stops. I gather the switch detects a rise in the voltage and it causes the slide to stop.
Possiblely if you let us know what type of slides you have we might be able to come up with more help. Doug Rainer is the geru when it comes to many of these problems.
