- wolfe10ExplorerYup, need to know brand of jacks. And, under what conditions do you have the alarm on?
- Old-BiscuitExplorer III
Amberlynn072 wrote:
My jacks don't have a single reservoir for each jack. It's centrally located in front the coach in a single unit that feeds all jacks.
Most 'jack down' alarms are done with reservoir level sensor vs actual physical position of jack
Low level OR faulty sensor - Dick_AExplorerWhat brand of levelers do you have?
- Amberlynn072ExplorerMy jacks don't have a single reservoir for each jack. It's centrally located in front the coach in a single unit that feeds all jacks.
- TrackrigExplorer IIIf the fluid level in them is only slightly low, they'll beep. I had to add what amounted to a couple of tablespoons to stop mine from beeping. Mine had worked just fine for a couple of years and then they started beeping one morning when I raised them. I checked the fluid level and it looked fine. There was no leakage that I could find so I don't know why they started beeping.
Bill
38,705 PostsLatest Activity: Jan 21, 2025
