x0054's avatar
x0054
Better Gas Milage and Shift Lock on e-350 based RV?
Hi everyone!
We have a 21 foot 1994 Shasta RV based on a e-350 Ford with 460 engine. We are getting about 9MPG, maybe just over, on South CA roads. Any ideas on how to move that up a bit, maybe to 11-12 MPG? I read that maybe a wind deflector might help, to prevent the wind from getting trapped under the cabover bad. But googling around I have not seen anything. Is it worth it, and any links on what I could get?
Any other ideas?
Also, I am looking for some kind of way to lock the damn transmission in higher gears. The RV has a massive engine that isn't working hard at all when pushing the RV around. But any time we start climbing a steep heal, the transmission kicks down to what I am guessing is 2nd gear. It's quite annoying, especially considering that every vehicle I have ever owned since I learned to drive was a stick-shift, and I am not used to having some computer telling me what gear I should be in. Maybe there is a hack that can trick the transmission into not downshifting while a switch is toggled. Like a shift lock switch? Again, not sure if it's possible, but any ideas would be much appreciated.
- Bogdan
