2011 Winnebago 34Y. The full wall slide is dead! Push the button and nothing, no lights, no nothing, slide won't move. All fuses and circuit breakers check good. HELP!
I turned the key to the slide panel off once and took the key out...Not sure if you have that part...I was puzzled for a while on that...or check motor control switch on the motors, make sure it is in the lock position, no in between. Just a few thoughts...
