Finally Got with Winnebago for some help with this. Was told to check the micro switches on the slide locks, as if they are open no power gets to the control switch. Checked the back one first and all looked good, micro switches closed, but when I moved my hand around one of the switches a wire fell off. Put it back one and tried the slide, still nothing. Went to the front lock and took the cover off and found one of the wires to the front micro switch just hanging loose, not connected! Put it back on and the slide works perfectly!
Thanks Winnebago!!!
