JimMartin's avatar
JimMartin
Bigfoot levelers not working
I have a 1998 GeorgieBoy CruiseMaster 3590 DP with the Bigfoot leveling system on it. I bought this RV about 4 months ago from the original owner. He told me he hadn't used the jacks in years. I put on RV up on blocks, Ran all four jacks down all the way, bleed the air out of the system, and topped off the 4 separate fluid reservoirs. Ran the jack all the way back in, put the RV back on it's wheels to try and test the system.
All four jacks will go down just fine. Front ones will rise the front of the RV about 4"s, Won't lift the wheels out the ground, but when I left off the switch the jacks go back down about an inch.
Rear jack hit the ground and do nothing?
Should these jacks be able to lift my RV off the ground, or at least level it? What am I doing wrong?
  • Are you using the "Auto" setting? on my fiver, which may be different than a MH, the front jacks level front to back, then the rears come down and just touch, then both do the side to side level.
    It will lift all eight tires on my fiver off the ground, but only in the manual mode.
    Call Quadra, they are really helpful.
  • when you filled the reservoirs. Did you have the jacks retracted? They should have been.
    Go to the Quadra.com web site. for Big Foot. or call them for help.
  • Yes, my Bigfoot Levelers will lift my 45' MH off the ground.....
