rgatijnet1 wrote:
Old-Biscuit wrote:
rgatijnet1 wrote:
Mine got plugged also and I ran an electrical snake through it to clear it out. An electrical snake is smaller than a plumbing snake which is used to clean out drains.
How do you get the wire thru the 'anti-siphon vacuum breaker device' ??
As for Pressure..........PEX Tubing
Long-term Pressure Ratings:
*160 psi @ 73.4°F
*100 psi @ 180°F
*80 psi @ 200°F
I just ran the wire in through the connection where the exterior hose connects. Don't know what is in there but the wire cleared the obstruction the only time I have had to do it.
Couldn't have pushed wire too far.......
RV MFGs. are required to install an Anti-siphon vacuum breaker.
They usually are inside bathroom sink cabinet..seen them in closets too.
