Rolin
Aug 08, 2013Explorer
Black/Grey Tanks always show empty
The Black and Grey water tanks read empty all the time. Have been trying to get information on-line regarding how these things work but have not yet been successful.
The propane tank, the fresh water tank and the battery level displays all work correctly. I don't know if there is a ground connection that is common between the black and grey tanks. Tomorrow I plan to remove the access panel under the shower to access the top of the tanks. Not sure what I will find. The goal is to verify the connections to the tank sending units.
I assume that if a ground is missing then the all of the lights on the effected display would be off? So I am not sure what is causing this malfunction.
Has anyone encountered this problem? Any solutions?
