onecolbs
Mar 12, 2015Explorer
bleeding air breaks
I have a 2001 bounder with 51000 miles. Should i have the break lines bled? And where do I find where the lines bleed from? thanks. Just trying to learn.
bigdisplay wrote:moisheh wrote:
Note that the replies about taking an air brake course are all from my fellow Canadians. In all 10 Provinces you are required to pass an air brake course. One poster wondered why? Your answer is in the original post ! NO person should be allowed to drive an air brake vehicle without passing the test. In Canada you are not allowed to adjust the slacks unless you are certified. I have a CDL and an air brake endorsement and am certified to adjust the slacks. BUT if the slack adjusters are functioning properly they should not need adjusting. Auto adjusting slacks have been on most vehicles for about 20 or more years. I would ask all of our American friends if they know what "performing a 6 pack" means? If you cannot answer that question you should not be driving an air brake vehicle! There are also some simple tests that one should understand and perform. I might add that most jurisdictions do not allow you to adjust air brakes on a MH ( or any other low slung vehicle) at a weigh scale. Far to dangerous to get under the vehicle without supports. A complete guide to air brakes is published free on line by most Provinces. They are all similar.
air brake manual
that manual and that test/course is for commercial trucks and trailers
WAY WAY too complicated for just a Class A MH.The governments need to bring out a MH only condensed form and course dedicated to just MH
No one needs to know about trailer connections and break away valves etc etc
air brake manual
air brake manual
JaxDad wrote:
Funny, after 2 pages of comments I don't see anywhere the OP said his rig has AIR brakes, there's not even a description of their rig in their profile.
I'm pretty sure there were lots of Bounders built with juice brakes, some of which might need bleeding, but more lkely new master or wheel cylinders.
VintageRacer wrote:
They are brakes, not breaks. You don't bleed air brakes. You do drain the moisture from the wet tank. Lord have mercy...
bluwtr49 wrote:mowermech wrote:
Thank you. Now we know that in Ontario we can't adjust our own air brake slack adjusters. IF that rule applies to owner-operated, non-commercial vehicles, and IF that rule also applies to non-residents who may not have to have such a certification.
That may seem like a silly question, but here in the United States quite often the rules for commercial vehicles do not apply to the operators of Recreational Vehicles.
In fact, some states do not require an air brake endorsement on the driver license of the operator of an air brake equipped motorhome.
I've heard of an air brake endorsement. Wonder why that would be necessary.
