timmac wrote:
azdryheat wrote:
Everyone is assuming the engine blew but we don't know for sure what happened. And I seriously doubt the engine was "working over time max weight every mile".
If they were towing a toad over 4000lbs and the weight of that 40ft motorhome its over its max weight for that motor as I see it, why to much of a motorhome for a gas motor, should have been a diesel.
My setup towing my stacker trailer weights 26,500lbs and in the mountains its working hard and I feel that's pretty close to max even though Ford says it can handle 30,000lbs max
Running max all the time puts to much strain on the drive train.
Just my 2 cents
Based on the OP’s comments it’s not very likely they were pulling a toad, otherwise they wouldn’t have needed a rental vehicle.
As for weight, everybody seems to be in the ‘sledgehammer to kill a fly’ crowd.
If the company that designed, built and warranties the drivetrain says itks rated for 26k pounds then I’ll take their opinion over that of armchair engineers every time.
Until recently, when they moved up to the E-450 chassis, nearly every class C was at or very close to its GVWR coming out the factory door. Lots of them went 100’s of thousands of trouble-free miles. My little 1995 24’ C is one of them, albeit with a 7.5 V8 under the hood, well over 200k on it and still going strong.
The 30k GCVWR is just that, a rating, not the point at which it explodes.
