- ApprovedAnonymous
ThorResidencyNewbee wrote:
Does anyone know of any good deals on the ReadyBrute elite tow bar?
Thanks.
See if this outfit near you can help you with your needs. I have been using them for over ten years.
http://www.brokenwheelrv.com/ - dieharderExplorerBeen using Brake Buddy. No issues here.
- ThorResidencyNeExplorerDoes anyone know of any good deals on the ReadyBrute elite tow bar?
Thanks. - deandecExplorerBrake Buddy is simple, portable, and expensive. From 12 years experience, I would look hard at the Ready Brake.
Ready Brake looks even simpler, inexpensive and just as portable.
But, I would not want a brake activation cable loop permanently sticking out on the front end of my daily drivers.
I do have a brake buddy activation connection hanging, but it is visually covered by my license plate. - ApprovedAnonymousTen year Brake Buddy user. No permanent set-up in your toad, and easy to connect and disconnect.
Good luck with your choice! - willaldExplorer IINeither. Do yourself a favor, save yourself a ton of $$ and headaches later on, and get you a ReadyBrake.
Costs less than half, no electronics to foul up and damage your brakes, nothing to have to put in and take out each time you tow. Just can't beat it, IMO.
On Edit: Haha, I see Dave beat me to it on this subject, by 'bout one minute. :) - DaveinetExplorerNeither one. Technically, you could not have bought the tow bar either, as you could have saved some money, but you can still work with what you have. Go to http://www.readybrake.com/brake-systems.html and set your self up with ReadyBrake. Its an excellent system, very simple dependable, and works very well. Tons of satisfied user of ReadyBrake users on RVnet, and I have no doubt they will chime in. Its simplicity means there is very little to go wrong. It is the only system that is truly closed loop, and actively provides the correct amount of braking, based on need, rather than a predetermined calculation. I'm very pleased with mine, and my toad weight to RV weight ratio is much more demanding than I any other RV set up I've seen.
- aihchris107ExplorerI have been using the Brake Buddy for three years now towing a Jeep Wrangler. Unit has been dependable and easy to set up, Chris S
38,774 PostsLatest Activity: Apr 26, 2026
