Coach stops OK, but takes heavy foot pressure. Not sure if this is an air problem or if I need brakes. Anyone know what a brake job costs on a class A diesel?
Come on guys, we get enough mis-information without trying for it.
Yes, the majority of DP's have oil bath front wheel bearings. And, yes if the inner wheel bearing seal leaks, it CAN soak the front brake components. Very easy to check visually if you are under the coach.
