I purchased a 2001 Fleetwood Southwind 35R in 2010. I had it inspected by a professional company prior to purchase. I had about 41k on it, now has about 44k. Not driven too often. They did not find an...
They make a high temperature grease just for caliper pins. Make sure that your mechanic uses it when having any brake work done. This will help to prevent your brake calipers from sticking because of non-use, which is what the symptoms indicate.
