I purchased a 2001 Fleetwood Southwind 35R in 2010. I had it inspected by a professional company prior to purchase. I had about 41k on it, now has about 44k. Not driven too often. They did not find an...
I just replaced all of the brake lines, on a 2000, F35. They were the same as a super duty, f550. The 2 front, were the same, the back had different numbers. The sound you hear when you touch the brake pedal is normal, it is the aux. brake pump, back up brakes when engine is not running, no vacuum boost.
