I purchased a 2001 Fleetwood Southwind 35R in 2010. I had it inspected by a professional company prior to purchase. I had about 41k on it, now has about 44k. Not driven too often. They did not find an...
All F53 are not the same. Almost every thing about the F53 changed in 1999. Including the the brake caliper mounting design. So all the old brake issues are pretty much eliminated. But those less informed are still bashing Ford brakes about sticking slide pins. Your hydroboost brake system does have a back up system that is driven by a 12 volt motor. NO vacuum used on your brakes. I suspect you'll find a brake pad loose and floating on its mounting.
