olfarmer wrote:
I had the same problem with my old P30, only on the front. I don't know why the fronts are worse than the back but I suspect that it is because they flex more from steering and are subjected to some engine heat.
I think you're right and like I said, I've never heard of a rear one causing problems. They're a lot shorter too and especially on the 97 chassis and up, which are quite long, even if you consider that a good bit of it, is metal tubing.
The rears, though, are a lot cheaper and available most everywhere.
