Little hint on disc brakes that you might find helpful..
Often times when a caliper is dragging, it's not the caliper but the brake hose.
What happens is, over time, the interior of the hose degrades and the inside rubber flakes off and floats in the fluid. When you apply the brakes there is a lot of pressure pushing to clamp the pads to the rotor but when you release the brake pedal, the only back pressure (to retract the pads) is provided by the piston seals and it's not much. If the hoses are degrading, which they do over time, those rubbed flakes inside the hose can block the fluid from going back towards the master cylinder, hence, the pads drag, heat up and bad things happen.
My rule of thumb is I replace the brake hoses every 2nd brake job or every 5 years, whichever comes first or you can go to aftermarket stainless steel brake hoses and eliminate that issue entirely.
Don't be surprised that when you do get the brakes done, the pads still drag (if you don't replace the brake hoses as well.
