- rgatijnet1Explorer III
brobox wrote:
That is what I tried to tell him to do, but he gunned it in reverse and the rear end went BAM!....clunk clunk. I think he has had it rear end wise. Thanks for reassuring I didn't tell him wrong.
I'm guessing the rears were drum brakes and what he probably did was shift one of the brake shoes until a spring popped. He now has a loose brake shoe that is flopping around inside the drum. If this is the case, the wheel will have to be pulled to fix things. - DSDP_DonExplorerWhen the brakes let loose after being rusted to the drums, they do let go with a bang. He may not have done any damage.
- broboxExplorerThat is what I tried to tell him to do, but he gunned it in reverse and the rear end went BAM!....clunk clunk. I think he has had it rear end wise. Thanks for reassuring I didn't tell him wrong.
- klmExplorer
J Walker wrote:
It has happened to me. I just put it in reverse and gently hit the accelerator. Put it in forward and do the same. After a cycle or two of this he should be fine.
2x - The_TexanExplorer
J Walker wrote:
Same here, done it several times.
It has happened to me. I just put it in reverse and gently hit the accelerator. Put it in forward and do the same. After a cycle or two of this he should be fine. - J_WalkerExplorerIt has happened to me. I just put it in reverse and gently hit the accelerator. Put it in forward and do the same. After a cycle or two of this he should be fine.
38,738 PostsLatest Activity: Jul 26, 2025
