RV particulars: Damon w/ Workhorse P32 Chassis
Driveline: GM 8.1 4L80E transmission
Miles: 8,000
Year: 2001
Break Down Description: Cruise Control shutting itself off
Symptoms: Slow down.
Effect: Just like you press the brake or turn off the Cruise switch.
Outcome: Problem was a manufacturer defect. Something to do with a resistance wire in the harness to the brake lights. The Cruise Control was sensing this as the brake lights coming on so would shut itself off. Took two tries at the dealer and calls to Workhorse to take care of a fix.
