RV particulars:
97 Monaco Dynasty 40' Pusher
Driveline 350 Cummins - Allison 3000 World Transmission - Kingcruise throttle and cruise control
Miles: 36,000
Year: 1997
Break Down Description: Throttle would not work - intermittent problem. Would come and go without any indication of why.
Symptoms: Transmission ECU display showed "service" under Mode indicator light. Would shift into D and R, but no throttle.
Effect: Stuck - could not move.
Cause: Loose or dirty connection in 12v hot and/or ground wire between cruise control computer and coach 12v supply/chassis.
Outcome: Unplugged all electrical connectors to cruise unit and throttle position switch; cleaned with spray electrical contact cleaner and reconnected several times.
Helpful resource: King cruise web site. SEE my other post on the Tech forum for details for thi smust have free publication for troubleshooting the King system. Feel free to contact me if you have same problem. I fixed it in 5 minutes with the guide's help.
