RV: 1994 Fleetwood Southwind Storm 28ft w/Chevy P-30 454TBI & 4L80E trans (now 56,130miles)
While on my recent trip (Seattle to HB, Ca.) I had a trans slip issue start up while on the last leg of the pass just south of Ashland, Oregon. After cresting the RV would not go beyond 30-35mph. Pull off at Yreka, Ca. stayed the night (Baxters Auto lot).
The next morning they sent me over to Onarheim truck repair. Mechanic checked what I had checked (fluid) which was perfect no issue. He also drove it without issue. Says it may have gotten hot.
Continued on south. Made it to HB, Ca. (shot over from the 5 to the 101 via 505 - 680 - 101). No issue/s.
On the return trip ~10 days later just south of Willits, Ca. (during a grade) I had it do the same thing again. This was after driving without issue from HB, Ca.
Same results next morning no issue. However roughly 35 miles later same issue popped up (grade pull). This time I could tell the trans was in limp mode. Not going from 2-3. Quickly realizing that when turning off the engine and restarting it resets and all is ok. Now beginning to look like shift solenoid issue. Did this (2-3) more times until I reached Grants Pass, Oregon and stopped the night. Ended up staying just outside of Jerry's Clutch & Transmission (Great guy). While stopped I used paper clip to pull codes 68 and 87.
The following morning (Joe) mechanic used computer and pulled same codes:
68 - Trans slip
87 - Shift solenoid stuck open
He quickly fixed it by stating the 68 slip code can be resolved by turning the force valve up 1/4 turn and we'll replace both shift solenoids A & B.
While we had the RV up on rack he also found that the trans wire connector was leaking (internally) as well. Replaced it with upgraded one. Back on the road in roughly 2-3 hours. $290
So if anyone ever has trans issue I highly recommend Jerry's Clutch & transmission in Grants Pass, Or.
