malojeer's avatar
malojeer
BT Cruiser Emergency start switch
We bought an 07 Gulf Stream BT Cruiser model 5211 on a chevy chassis yesterday from a man that has severe form of memory issues and couldn't remember what the emergency start switch was for. I presume its to connect house batteries to engine battery. What is the correct way to use this feature if you need to?Thanks for any help
  • The emergency start switch is often used to start the generator. The coach battery(s) can get run down and you may want to use 120 volts for something. Either way, the switch connects the 2 banks of batteries.
    The engine alternator would charge the coach batteries faster, but it would burn more gas and be noisier.
  • What navegator said with the addition of "from the house batteries."
    And you have to actually HOLD the button down while using it.
  • When the engine battery is low or empty, you push the emergency button and then turn the ignition key to start the engine.
    navegator
