OhhWell
Dec 30, 2013Explorer
Dutch_12078 wrote:OhhWell wrote:D.E.Bishop wrote:OhhWell wrote:
They do significantly reduce the exhaust volume. The Gen-turi extends the exit end of the ell about 3 inches or so into the PVC which helps even more with sound abatement.
I looked at one in a supply store before I built mine and the ell was just short of the pipe (about 2"), I was told that was to cool the exhaust gas. Has there been more than one design from CAMCO?
There must be. Mine is labeled as Gen-Turi on the bag and each piece. It definitely extends into the tube and was designed that way. The opening of the PVC is not tapered or anything so there is plenty of airflow around it. Adding another small piece to your ell will get it in the tube and reduce the exhaust noise even more. I will try to get a picture of my gen-turi when I get home.
Yes, please post a picture. The photo below is the only Gen-Turi design I recall seeing since they were introduced some years ago, but I may have missed a change at some point.
Old thread, I know. Sorry it took so long but here is a picture of my Gen-turi with the el pipe terminating inside the tubing.
38,782 PostsLatest Activity: Aug 11, 2021
