- StimExplorerI had fill station refuse to fill one because the handle stem leaked if it was half opened.
All the way open or closed it did not leak.
I tightened up the nut on the handle stem sealing the stem and it didn't leak anymore!
Got it filled. - Old-BiscuitExplorer IIINO........
Permanently mount propane TANKS fall under the ASME/NFPA jurisdictions and do NOT have re-certification requirements
Permanent mounted TANKS need to be replaced if heavily rusted/pitted or damaged due to accident/fire
Portable propane CYLINDERS fall under DOT jurisdiction and do have re-certification requirements.
OPD valves, Inspection/certification 12 yrs AFTER date of Mfg stamped on collar (10 yrs in some places....requirement was changed from 12 to 10 then rescinded for review but both 12/10 can apply)
TANK vs CYLINDER
Two propane vessels but different - zigzagrvExplorerWhat eubank said!
I was told during one fillup my tank was questionable. I spent a few hours sanding and repainting my tank and inspecting it for deep rust. Fortunately, it was all surface rust. - eubankExplorerI suspect that the motorhome you're looking at has fixed-mount cylinders, not ones that can be removed. IF so, then you have ASME cylinders, not DOT cylinders. ASME cylinders do not require recertification; DOT cylinders do. (That said, if your cylinder is in bad shape, then fillers can refuse to fill it.)
Here's a bit more propane info for you:
https://salem.wbcci.net/files/2018/06/propane-workshop.pdf
Lynn - garyemunsonExplorer IIYes. Getting them recertified can be a challenge.
