mitchtamExplorerJun 23, 2013Bump Out Not WorkingI have a 2007 sunseeker. My Bump Out motor still works, but it does not make the bump out work. When I closed it manually (by Pushing it) the bottom will not close all the way. Any Suggestions!!!!!
4 RepliesReplies sorted by Newestmayo30ExplorerJun 23, 2013Check the drive under the slide you have a sheer pin broken.workhardplayha1ExplorerJun 23, 2013Broken gearsdonn0128Explorer IIJun 23, 2013Weak or dead battery, broken gear in the mechanism, stuck slide out.rvtenExplorerJun 23, 2013You lost me.Bump Out= Slide Out?Is E Brake set?Battery switch on? Plugged into Shore Power?
Related ContentNot all Aftermarket bumpers work2003 newmar freightliner speedometer stopped workingMystery BumpEnergy Upper Bumps ***UPDATE***Bump on 2019 Eagle?
