apackard18
Jul 26, 2015Explorer
Burning Smell and super hot lights
Hi all, I have just purchased a 1980 Ford E-350 FAN motor home. This is my second purchase of an oldie, but they seem to do me well for the local camping trips I frequently take.
As with the first one, I took the RV to the local KOA for a night to test all of the systems and make sure I have no major issues. This time I did.
First, the back story:
The coach battery has been dead since I bough the unit, so I have been plugging it in at home via a standard 110 outlet when I work in it. (It's nice having A/C while working in it.) The unit is a 30 Amp system as was common with the old guys, but my adapter is a 15 amp adapter for my 110 outlet. The other day I decided to just leave the system plugged in all day and night. The next day after getting home from work, I popped the hood and noticed that the coach battery was super hot and boiling.
Fast forward to my trip, I stayed in a KOA with 50amp hook-ups. Again, I elected to use my standard extension cord with my 15 amp 110 adapter. Knowing the battery overheated the last time, I disconnected it. Everything seemed to be working fine. Then it got dark and we powered on the lights. 15 minutes later we noticed a bad burning odor. It smelled like melting plastic. We pegged the lights as the culprits. They were super hot.
I guess the question here is, does this sound like a grounding issue or a problem with the inverter? I did pull the cover off the AC breaker box and noticed 1 of the two wires leading out (black wire) looked like it may have melted a little. I also noticed that the fan on the inverter doesn't seem to coming on anymore since the battery incident.
One more note, I did switch from the standard incandescent bulbs to the plug and play LED's in between the battery incident and this trip. That said, the few left over incandescent bulbs were getting just as hot if not more then the LED's.
Thanks in advance for your thoughts on this.
