ratfink09's avatar
ratfink09
Cab Leak
Drove our 2011 Thor 28Z Chateau (F-450) after very heavy rain lately here in upstate NY and was drenched with a stream of water coming from the head liner on the drivers side. Looked under cushions in over head bunk and it ewas wet. Had to dealer about a year ago for same leak. Any one have the same experience and where was your source of leak?
  • On my last Class C I had a similar problem and found the leak was really at the rear of the MH and had water running forward. I also had leaks around the front window. All that unsupported weight on a Class C does not really work for a tight seal anyplace. I have not had a problem like that since switching to A's.
  • I do not have the same MH. But first place to look is clearance lights. Then side window.
