Having_Problems's avatar
May 05, 2016
leak over cab Window?????
Still have minor leak
I feel it is at the side window of Bunk Area
Decided to buy 10 ft of rubber gutter material & apply over top of window & down both sides
Has anyone done this & if so how successful were you in applying this material & does it stay stuck to side of Motorhome????
Thanks
Ted Class C 2006 Fleetwood Jamboree 23 E
  • Something else to consider. I ordered my 'C' new at a local dealer. When it came in, they invited me in for orientation. One of the things they showed me was the marker lights in the cabover. They removed the chrome covers to show me that there were no cracks in the underlying fiberglass. The covers are installed at the factory with high speed screwdrivers. If they over tighten, it can crack the fiberglass, creating a potential water leak that you'd never look there for. Mine was fine.
  • I would have the rig pressure tested ... finding leaks is a major PIA and the source is often a long way from where you think it is. If your sure the window is the actual source then removing the window and replacing the putty tape isn't very hard - lots of videos on Youtube.
  • I would find a dealer that could perform a "leak" test, that was the only way that I found my LEAKS after "guessing" for over a year..My dealer charged $100.00 and allowed me to observe the test..
