lanerd wrote:
Having a smog test is NOT the issue! As mentioned previously, the mh is EXEMPT from smog testing as are all dp mh's over 14,000 lbs.
We don't have a "CARB TAG". The engine emission label has on it: "EPA CARB", but we're not sure if that is sufficient or not. We have taken a picture of the label and will be going back to the DMV again tomorrow with the picture and see if this will do it. I'm sure they're gonna say: " you gotta bring the mh to us to inspect ourselves". We'll see.
The ISSUE is: the engine has to be California Emission Certified by the manufacture and they have to provide a label on the engine that signifies such. We have found the label, but due to the almost inaccessible placement of it, it's almost unreadable. We may have to contact Cummins (or Freightliner) and see if we can get a duplicate label.
The inspector in Bakersfield DID NOT open the engine hatch to look at this label and as such probably did not certify (on the inspection form) it as meeting the CARB standards; hence, now the requirement for an DMV or LEO to physically inspect it "again"!
On top of everything, the DMV double charged us the registration fees and now we are trying (for the past two months) to get the $1800 refunded to us.
Totally frustrated over this whole ordeal.
Ron
Take a look at this
wikipedia page I see your motorhome is a 2013. That first paragraphs describes other states that have adopted the California standard for emissions and it says the are all considered "CARB" states. It says started with the 2011 model year vehicles Oregon was a CARB state. So it sounds like your label is in fact saying your DP meets CARB standards for Oregon which should be the same as California.
Maybe the answer to your issue with California DMV is in Oregon. You may be able to get something from them indicating the motorhome meets Oregon standards which as of 2011 was the same as California standards.
