hanko wrote:
with voltages up and down as you described I would guess that the neutral or the grounded conductor was the cause, at the pedestal or the campground system. On a 240 volt 4 wire system that you have, interruption in the neutral will cause all kind of weird voltages.
Had this happen at the house once - neutral burned in two in the underground feeder to the house. Turn on the electric stove and the living room light turned on and several other anomalies, but nothing fried. The ground was steaming when they dug it up. Talk about weird . . . .
Maybe a loose neutral wire bolt in the pedestal? Mostly connected but not tight. Definitely qualified electrician material.
You might be able to "work" your connecting cable, box where wire enters the MH, pedestal outlet, pedestal, pedestal circuit breaker, pretty much anything you can put pressure on that might slightly move and monitor the "bad" side (with RV breakers off!). That might help zero in the location.
Best,
- bob
