etruitt's avatar
etruitt
Can I take my big truck with me?
04 Dodge 2500 long bed 4 door cummins turbo diesel truck towed by 09 35' Holiday Rambler Neptune 340 HP cummins diesel with 6 speed Allison World transmission and 9000 lb. hitch. Already have the truck from pulling trailers and carrying slide-in truck camper in the past. If this combo will work I won't have to find a toad and can keep our truck. We travel cross-country each year. Any advice and opinions welcomed and appreciated. Usually our trips are 2-3 months and 7-8K miles. Not being the brightest light in the barrel I just looked in the owners manual for the truck and found out it can be towed.
  • That truck is already set up to tow travel trailers, 5th Wheel trailers, and carry slide-in truck campers. What does it take to set it up to be towed 4 down?
  • msmith1199 California is a beautiful state. We have RV'd a large part of it. We usually go to see our daughter in Oregon and explore after that. Have to cross the Appalachians, Rockies, and the Cascades to get there. My mountain driving makes my DW nervous.
  • go to a gravel pit and ask them to weigh your truck for you they will probably do it for free
  • I just checked the window sticker/spec sheet and it lists 7000 lb hitch receiver with dual connector. Does that mean my "tow rating" is only 7k lbs or does that mean the receiver will handle up to 7k lbs hitch weight? Probably sounds like a stupid question but if I knew the answer I wouldn't ask.
  • And the good news is if your motorhome ever breaks down you can flip things around and tow it with the truck! But on a serious note, I have a 35 foot DP with a 330 HP cat and I tow a Dodge Dakota 4x4 with it and I used to tow a Jeep Liberty. When I went from the Liberty to the Dakota I could feel the extra weight back there and the loss in performance. I wouldn't even think about towing something of the size you are talking about myself, but I live in California and we have mountains here.
    The problem I see for you is you may spend a lot of money setting it up to be towed, and then find out you don't like it at all once you have it set up.
  • Shipping weight on the truck shows as 7100 lbs. For some reason I thought it weighed around 8500 lbs. What is "tow rating" and where do I find it? I've only had the motorhome about 7 months so new to this type of RVing. What kind of equipment is required and about how much $?
  • If the truck can be towed 4 down and it's under your tow rating, I don't see why not.
  • It is within the specs of your hitch. Take your time and it should be no problem.
