enblethen
Nov 05, 2015Nomad
If you have any the fuses would be in the front outside compartment under the driver's area.
Do you have amber turn signals on MH? If so there is a 3-2 converter. Many times it is located adjacent to the hitch. Check the ground on it. Some do not have ground and do not affect the taillights.
Next, Use your meter to check the MH connector. Starting with the ground.
38,763 PostsLatest Activity: Dec 05, 2025
