04revolution
Nov 06, 2015Explorer
I have a 2004 fleetwood revolution and the fuses behind the batteries are for each line out of the connector as you probable have discovered by now. I had a bad cable after 5 years of use. Only shorted the left turn signal line but took out the fuse for that line. In my fuse block the fuse use is marked. Hope you have resolved your problem
38,763 PostsLatest Activity: Dec 05, 2025
