Have 2001 Itasca Horizon diesel pusher, with CAT 330 (3126B). Changed filters, fuel and water/fuel filter and now it will not crank. Any help is appreciated.
There should be a pump on top of the engine nearer to the front of the RV Raise the bed and find it. Pump and get air out of the line. You may have someone pump while you crank the engine over. Soon it should get air out of the line and crank. Do not crank for longer than 30 seconds at time and give it rest. Best to you. Arnold
