Dale_Traveling
Sep 17, 2014Explorer II
It's not the exterior you need to seal but the hole behind the light for the power wires. Completely remove the light and use plumbers putty or similar material to create a seal the wires pass thru. Also goop on sealant such as caulk to the threads of the hardware that hold the light in place.
