howdy35's avatar
howdy35
Explorer II
Jun 29, 2013
Centramatic, Balance Master, or Other?
Is anyone using the Balance Master, Centramatic or other means of balancing your steer tires? Mine have developed a little hop and I would like to address the issue before long.
I have a place that puts on the Centramatic not far from me but don't know where the Balance Master people are. In the past have used equal but had a flat spot show up on both tires so am not too sold on it.
Thanks for your input.
  • I installed the Centramatics on my rear axle a few years ago. My coach came with the Goodyear G670 tires which I later learned to hate due to separations and rivering on the front tires. At 40000 miles I changed out my original rear tires with new GoodYears and added the Centramatics. The Goodyear's I took off of the rear were not bad, but had some odd tire wear on each tire. I now have about 15000 miles on the rear tires and all four are wearing perfectly. I have to attribute this to the Centramatic.
    After replacing the rears, I got another year out of the front GoodYears that I had already replaced twice. This time I went with the Hankooks on the front and tried balancing beads for the first time. The Hankooks are wonderful 10000 miles later and are wearing perfectly.
    I like the Centramatics on the rear and will never have to balance them again. I don't know if I would pay for the Centramatics on the front because the beads have worked so well.
  • We, like many Airstreamers, use Centramatics with good results. So much so that now Centramatics has started distributing via a couple of Airstream dealers.
    Lynn
  • rgatijnet1 wrote:
    RV specific Dynabeads are much less expensive and will keep your tires balanced at all times. A single flat spot is NOT an indication that your tires were out of balance. I would guess that you had a brake lock up that you did not feel.
    X2
  • I bought the Centamatic for the front wheels of my W22. It did absolutely nothing to smooth the ride.
    I traded the tires with rear and that helped but the Centramatic gadget still didn't do what was advertized. When I sold the MH I left them on and didn't even attempt to take them to the new MH. Waste of money.
  • I haven't used them on my coach, but have used them over the years on our fleet vehicles, 33,000# GVW up to 80,000 GVW and been satisfied. It just seems that the initial cost is quite high for much more limited use vehicles like our motorhomes.
  • RV specific Dynabeads are much less expensive and will keep your tires balanced at all times. A single flat spot is NOT an indication that your tires were out of balance. I would guess that you had a brake lock up that you did not feel.
