Thanks. Brett I knew you would reply! I haven't opened up the floor in the closet but looking from below there is no room for the primer pump unless you get some type of adapter to mount it lower down. Regardless if you have to open up the floor to pump might just as well do the prefill. When I prefill a fuel filter I have a selection of plastic plugs that come with Fleetguard filters. These are the same plugs that hydraulic shops put on new hoses. I am very careful to pour into the outside holes.. My container is spotless BUT when you go to a service station the pump nozzles can be dirty. If I move that filter are there any requirements for mounting height? Can it be mounted to a frame rail? I am used to our side rad Dynasty. When you open the engine compartment door both fuel filters and the hydraulic filter are right there! Don't even need coveralls!
Moisheh
