sssooo's avatar
sssooo
Changing holes
When changing hole location on the bar do I have to change the location on the top of connecting rod
I hav a 2013 Tiffin on a ford chassis
  • TNGW1500SE wrote:
    The only downside to the CHF is when you raise the front end, the tires come off the ground sooner. You can get longer sway bar links the solve that issue and also level the sway bar back up.
    WHAT! Can you explain this please.
  • The only downside to the CHF is when you raise the front end, the tires come off the ground sooner. You can get longer sway bar links the solve that issue and also level the sway bar back up.
  • I did change the top one so they line up properly, from memory it was not very reasonable not to.
    you simply move the link to the rear holes on the front bar you don't need to move the top ones and its a fair amount of work but may be a slightly better mode but ask MB cause he knows more than all of us
    before u do what I suggest
