Useroverdrive's avatar
Mar 12, 2014
Changing/replacing city water inlet connector
Hello all,
not sure if this is the correct section to post this, so moderator move it if needed. Here goes:
I have a 1989 Mallard Sprinter class A and I need to replace the city water inlet. I have tried a couple of different water hoses and replaced several different O-rings and I still have a leak behind the hose connector. The check valve is in good shape so thats eliminated. The city water inlet is brass on the back side, goes through the city/gravity hatch and is pressed into the hose connector on the front side.
Is there an easy way to replace this? I have found a lot of threads that say,"just replace it, it's easy", yet theres no explanation of what I need to do. Do I grind the inlet in half? Cut a circle around it and replace with the new one? For that matter can I find a through wall coupling and add a hose connector on one side and water line connector on the other side?
I'd appreciate any input that you all can provide
Thanks,
DS
