Sam_Spade
Mar 15, 2018Explorer
10forty2 wrote:
As said above, I suspect that yours, like mine and many others does not charge the chassis battery(s) when plugged into shore power.
He said that his did before. So does mine.....now.....after replacing the "battery solenoid" which I assume is a common problem 'cause I've had bad ones on my last two units.
If that solenoid is bad (usually burnt contacts), other things won't work either......like the emergency start which cranks the engine from the house batteries and house battery charging from the chassis when going down the road.
I think parts and labor was around $100 in both cases.
38,706 PostsLatest Activity: Jan 20, 2025
