Capone
Mar 15, 2018Explorer
Ok, so a little closer. As it turns out there are two solenoids in a box under the hood just below the a/c coil and I was able to determine that only one small wire connected to the coil of one of the solenoids has voltage on it with the use/store switch set to use, but if the switch is set to store there is voltage on just about every wire in the box. After leaving the switch in store for about 2 hours my voltage went from 11.82 to 11.83 so the plan is to leave it as is until morning and recheck the voltage.
38,706 PostsLatest Activity: Jan 20, 2025
