T-Rex's avatar
T-Rex
Check Engine Light...Going on 5 years & 20,000 miles...
After 5 years (and 20,000 miles) of owning my 2007 Class C RV with an E450 chassis, I am finally committed to resolving what should have been addressed right way. The prior owner had taken the RV to a Ford Dealership service center after seeing a Check Engine Light (CEL), and they replaced an oxygen sensor for over $600. The problem initially appeared to have been resolved, but soon later, it reappeared. Since it never posed a significant problem, I've always just erased the code and went on my merry way. I recently saw a forum post stating that a "stuck lean" code could indicate a problem that may be engine damaging, and so I'm FINALLY anxious to get this properly resolved.
When I start the engine for the first time on a given day, the engine usually runs fairly rough and sounds like it may stall (though it never has), and sometimes this rough idle is accompanied by the CEL. Eventually it "smooths out" on it's own, especially if I give it a little gas. If the engine has already been warmed up, and I start the engine, it immediately runs smoothly and no CEL appears. Over the past year or so, it's only been a P2195 code, but previously, I've seen P2196, P2197 and P0105.
If it's not too difficult, I'm willing to try replacing sensors with new ones or just clean the existing ones. Even if I guess wrong once or twice about which part is defective, I'm probably better off financially than if I took it to a Ford dealership.
I would really appreciate any thoughts of the root cause of this issue given the signs and symptoms above, and thoughts about a novice tackling a repair himself.
Thank you,
Eric
