TinyoneRV
Sep 25, 2013Explorer
The real inconvenience is freezing up the slides with dirt and rust so you can't pull the battery out for maintenance. I recommend you grease the slides liberally with a spray lithium grease every time you open it for any reason. You're battery is not being harmed by the mess of dirt you see. BTW, I use a silicon lubricant on the slides in the front compartment. Also, you don't want to seal the compartment too tightly or the gas created by the battery can't escape.
