booty51's avatar
booty51
chevy gear heads
I have a 1996 p -30 chases with a 454 J code engine. It will start up and run fine (engine cold). After the engine warms up engine will crank but makes no attempt to fire. I drove rv from storage to the house (about 20 miles) backed into the drive. Tried to start rv later and it just turned over never firing. I let it sit over night and it started right up. I turned the engine off and restarted a couple of times sitting in the drive Idling again engine cold. I warmed up engine. I was showing engine temp. and shut engine off. Tried to restart and all it does is crank,never attempting to fire. Is it a coil issue? Also Is this coil external ?
