luvz2cook's avatar
luvz2cook
city water fill help...
hI,
I just bought a 2001 rvision trail lite class b+..
trying all the systems today...most everything works but...
when I hook up the city water to the unit and turn it on no water goes to the faucets...what am I missing??
also, filled the fresh water tank 1/3 full, tried the water pump...it sounds like its working but does not pump water to the faucets...it does pump water out of the drain even though it is closed (I think it is, nothing drains from it til I turn the pump on)
any suggestions...thank you,
christine
  • First off.......
    Are you sure you are hooked up to 'city water' connection and NOT black tank flush system??
    Do you have a 'water panel' with switches/valves? If so...you need to line up the switches/valves for city water
    With water pump on Close that valve that water is coming out of....doesn't do any good pumping water out of the system onto the ground.
