williamp321's avatar
williamp321
City water fill
I have a 2003 346 Georgetown class a. This week end when we got back home from a trip i Hook the city water up. When i turn the water on it fill the fresh water tank. Been useing the motor home 10 years and it just started this. Help please
WIlliam.
  • Yep! I started having the same problem. I really believe it is the three way ball valve that started leaking through all of a sudden. To buy the original part from ShurFlow it costs around $400.00. I am planning on just buying a three way valve for around thirty dollars and change it myself. I do not need the plate that shows what the valve is opened to, filling tank or city water. The plate just shows when pointed in one direction or the other what it is doing. Not important to me. So it looks fairly easy to change out, we will see after the weather warms up a little. Too cold right now to do anything outside. LOL!
  • 4x4van wrote:
    If you have a valve to allow you to fill the tank from the city water hookup, it's leaking. If you don't have that valve, then the check valve in the water pump is leaking.
    X2, time for a valve repair or a new valve (depending on valve). It MAY be lime clogging it in which case if you are comfortable flushing the valve with lime-away it may work (but please rinse well if you do it this way).
    Correct......
    2 methods of water leaking into fresh water tank.
    'Fill Valve' OR pump internal check valve
    Disconnect pump suction line at pump, turn on city water and see if water backflows thru pump
    If thru pump.....running it, using the water in fresh water tank can flush any debris/deposits on check valve diagram.
    Otherwise....replace pump.
    If 'Fill Valve'----replacing it best cure
  • 4x4van's avatar
    4x4van
    Explorer III
